Discussion topic: Booster connection to the hub not working
This message was authored by: BAR10
Message posted on 27 May 2025 08:18 PM
The sky booster has 3 green lights but isn't working. I've turned the hub and the booster on and off and tried connecting using the WPS but the light doesn't turn green. We've had them both for about 4 years, it had been fine up to now, but suddenly stopped. The booster isn't visible when you search for it.
Message posted on 27 May 2025 09:55 PM
Re: Booster connection to the hub not working
@BAR10 Is it only the middle light off the sky booster that is not lighting up and going green? Model would be SE210 on it's label.
