14
This discussion topic has been answered Discussion topic: Blink camera wont connect to wifi saying incorrect password
This message was authored by: ali+Grocott
Recently changed my broadband to sky and when i try connect my blink camera it keeps saying incorrect password when it's the correct password? Anyone help?
Avatar for ali+Grocott
This message was authored by: ali+Grocott Answer
Re: Blink camera wont connect to wifi saying incorrect password
@jamesn123 Ive sorted it now hard reset on the blink. Thanks for your help 👌🏻
You may need to split the WiFi bands
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
I am NOT a Sky Employee
I have no option to untick anything?
@ali+Grocott
Which hub do you have?
@jamesn123 4.2 the latest one
@ali+Grocott
That is not quite the latest one, the latest one is a white hub with WiFi 6 built in.
Can you send a screenshot of what your seeing in the hubs admin interface where you can't untick it?
@ali+Grocott
That image does not show anything about not being able to untick anything...?
@jamesn123 Thats the screen that comes up when i follow those steps
@jamesn123 Managed to do it but it still won't connect
@jamesn123 Still wont connect, anymore suggestions
@ali+Grocott
If you managed to split the WiFi bands so you have two seperate SSIDs & the blink camera still wont connect I would triple check that you are entering the password correctly with the right characters & numbers. If it still does not work you'd need to contact blink
This message was authored by: Poppy1973
If you have broadband shield  go to settings and turn it to 18+ .... if that dosnt work contact blink throught the app and hey presto an update and all works ....
