15 Apr 2023 02:45 PM
Hi,
With my previous provider, I was able to connect an external HDD direct to the router via a USB port, and then use it as a shared network drive. Obviously, the Sky Hub does not have a USB port to allow me to replicate this and the only other option I have seen from a previous thread is to purchase a NAS server. Unfortunately, this is not an option at the moment so can anyone advise of a cheaper alternative to be able to do this?
Thanks in advance.
15 Apr 2023 04:24 PM
Posted by a Superuser, not a Sky employee. Find out moreThe only other way would be to buy a 3rd party router with a USB port and use that
15 Apr 2023 06:06 PM
Any suggestions for a router? Any specs, in particular, i need to look into?
17 Apr 2023 02:41 PM
Posted by a Superuser, not a Sky employee. Find out moreDepends if you intend to replace the Sky hub outright or just plug a router/AP into the Sky hub via ethernet
