Discussion topic: Bedrooms have very slow wifi
Message posted on 09 Jun 2025 09:02 PM
Message posted on 10 Jun 2025 05:53 AM
Re: Bedrooms have very slow wifi
If you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Message posted on 10 Jun 2025 07:10 AM
@IanI Did you change hubs black to white versions when you went to the Full Fibre connection, or was it just a hub to the new position wherever the ONT for Fibre was fitted?
Message posted on 10 Jun 2025 09:30 AM
@JimM1 it is a black hub in knew position were fibre was brought into house, fibre 500 it's great down stairs but sons computer not working.
Message posted on 10 Jun 2025 12:55 PM
@IanI To be honest the movement to suit the ONT position is not always the best option, and if your hub work with no problems and covered all the bases before then that would be the way to go, but it's one off those i need to extend the Ethernet cable to move the hub, can it be done well and not have major complaints, only you can say, Fibre should not hinder only make better for quickness and speed.
After that you are down to booster's and no guarantees those behave well, powerline not so good an option especially on the upstairs/downstairs can be a lot of cable and joints to get through so may end up a poor speed.
For me moving the hub has to be option number 1. HTH👍
