Discussion topic: Bad WiFi up stairs and other places
This message was authored by: Ali__
We have had sky for a little while know and it's not got any better with WiFi . Son is always complaining about WiFi speed /signal in his bedroom, my bedroom isn't. The best and the kitchen dinning room at the back of the house is awful, some places no WiFi signal at all
Re: Bad WiFi up stairs and other places
@Ali__ Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
