29 Mar 2024 11:48 AM
I currently have BT Full Fibre 100 with Halo with Complete Wi-Fi (Black Discs) alongside Sky Q (including Sky Q Mini boxes) which work well.
I’m looking to change from BT to Sky Ultrafast.
What can I buy to replace the BT Discs? Is TP-Link Deco (M4 or S4) a good option?
Will everything still work seamlessly like it does currently?
Thanks in advance for any help.
29 Mar 2024 11:56 AM
Posted by a Superuser, not a Sky employee. Find out more@ptf63 if you switch to Sky the standard SR203 Sky hub you will be sent will link to both the main Q box and the your Q minis. Each of the Sky boxes will act as a wifi hotspot which should allow devices to roam seamlessly. Of course the speed each hot spot provides depends on the signal the Sky box receives. Q is getting pretty old but still works for most people.
Sky will provide boosters to Sky Q customers whose TV boxes dont connect.
