Discussion topic: Awful Speeds over WiFi and Ethernet
Re: Awful Speeds over WiFi and Ethernet
@mormegil Seperate your Asus ssid's helps the 2.4Ghz devices, but the 5Ghz sometimes just a mind off there own.
Avatar for MJG65
This message was authored by: MJG65
Always on mains
Avatar for MJG65
That's a problem for me because I have a Samsung mobile and rely on calls over WiFi because there's no mobile network signal where I live.
@MJG65
Could you post a screenshot of an ethernet speedtest?
I am NOT a Sky Employee
Avatar for MJG65
@jamesn123
Screenshot showing speed over ethernet and wifi.
@MJG65
Something really isnt right with your line or the device there, the latency should be nowhere near that high on a FTTP connection & obviously your speed is way down. What is the model of the laptop? Is it direct ethernet e.g. your not using powerline or anything like that? Do you have another ethernet device you can test with?
Avatar for MJG65
@jamesn123  it's a HP EliteBook 840 G6
I work over WiFi. The ethernet connection is used by my daughter for work and gaming. Her PC doesn't have a WiFi adapter.
@MJG65
So the first screenshot was ethernet on your HP, the second was WiFi on your HP and the 3rd is ethernet on your daughters PC or have i got that wrong?
Avatar for MJG65
@jamesn123 correct
@MJG65
Then it seems your work laptop is the problem. Is it using some sort of VPN or special network firewall?
Avatar for MJG65
@jamesn123
I don't connect over VPN for work, but undoubtedly there are network firewalls in place. I'm not technically competent enough to say any more than that.
