Discussion topic: Asus tuf ax3000v2, no internet on fttp
This message was authored by: Callum39
Hi, I am trying to replace my router for this Asus one, I am on sky full fibre fttp and an open reach ont. I have seen numerouse post with random user/password combo's for  PPPoE and seen many others that says to use DHCP . I have tried both and cannot get a connection. Any help appreciated.
Re: Asus tuf ax3000v2, no internet on fttp
@Callum39
In the uk sky use client identifier option 61
Locate the above field and type in
anything@skydsl|anything
Avatar for Callum39
I can't find anything on the router about option 61 or a client identifier. Only DHCP, pppoe or static ip
@Callum39
Set wan connection type to automatic ip
@Callum39
Are you using the asus router app.
Try the web interface ip 192.168.x.x
Avatar for Callum39
I was, now. Fired laptop up and found it straight away, we have internet. Is there anything else I need to change I read somewhere about changing DHCP frequency from aggressive. Thanks
Avatar for Callum39
@Callum39
Checkout adaptive qos on the router asus app.  It allows you to priortise gaming, streaming etc in order of which is more important at anytime
@Callum39
In relation to dhcp query freq normally we advice to select normal
