Discussion topic: Asking to contact sky regarding order
This message was authored by: MartinBoyle
Hi there could anyone help? I've opted for sky and been told everytime I click the order it says to contact them I've received texts etc that it will be installed on the 24th but not showing in products / services or anywhere really
Re: Asking to contact sky regarding order
@MartinBoyle  You will need to call them as the community can't help with account/order issues.
These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🔶📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
🔶online help via this link
https://www.sky.com/help
🔶 Sky Assistant should also be available via
🔶Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required.
