3
This discussion topic has been answered Discussion topic: Arlo floodlight security camera not connecting to Sky Max Hub
This message was authored by: craigmail
Since having Sky FttP installled recently, my Arlo floodlight camera will not connect to the wifi. Things I've tried to rectify this:
  • Disabled 5ghz band at the router as the camera will only work on a 2.4ghz band
  • Reduced the wifi security to WPA2
  • Logged into the router and the camera appears as an "Offline Device"
Any suggestions?
Avatar for craigmail
This message was authored by: craigmail Answer
Re: Arlo floodlight security camera not connecting to Sky Max Hub
Thanks for the reply. The issue is no longer a problem.
@craigmail
Is it in decent range of the hub?
I am NOT a Sky Employee
I've resolved the issue now. The problem was the sky hub password which was incorrectly entered.
