Discussion topic: Are you allowed to use your own router instead of the sky hub ?
Message posted on 02 Mar 2024 06:50 AM
Are you allowed to use your own router.
Message posted on 02 Mar 2024 07:55 AM
Re: Are you allowed to use your own router instead of the sky hub ?
@BlackSwan83 Yes you can, make sure to do your research and get one that can be used with Sky as I believe on some lines they use Option 61 instead of Pppoe.
Message posted on 02 Mar 2024 08:36 AM
@BlackSwan83 to expand on @daveNOS 's post. Sky permit you to use third party routers but wontprovide support this means if youbwant tobreport a fault you have to connectvthe Sky hub as the diagnostics Sky use have to talk to the hub. You also want be able to use the voice service that Sky provide through the hub to replace standard phone sockets.
Sky do not use PPOE in the UK (Ireland is different) rather they use DHCPv4 Option 61 which most but no means all routers support. There is an alternative authentication method DHCPv6 PD but while that works on most lines it depends on the equipment in the exchange which means some dont.
If you are thinking about using a third party router searching the forum can often give you information on how to set it up. Asus models are popular but certain brands like TP-Link only work on certain services.
Message posted on 02 Mar 2024 08:53 AM
Thank you all for your quick and detailed response.
I previously used a ASUS RT-AC68U AC1900 combined with a Netgear modem for my ADSL line but now i have fiber and an ONT at the property it just isnt connecting.
Could i please ask if the above modem is compatible with sky fiber and also do i need username and password to handshake on skys end? Do i need to copy any other info from the sky hub to make it work?
Thank you in advance
Message posted on 02 Mar 2024 11:07 AM
Full fibre doesn't need a modem as the ONT takes its place, so you should be able to connect the Asus router you have to the ONT directly and set the DHCP Option 61 parameter to 'anything@skydsl|anything' without the single quotes in Asus router under the WAN settings.
Message posted on 02 Mar 2024 11:48 AM
Thanks for the info
so anything@skydsl|anything
Is that correct or do i need to seperate after @skydsl then |anything
Message posted on 02 Mar 2024 04:09 PM
That are no spaces in the DHCP Option 61 parameter 'anything@skydsl|anything'.
Message posted on 22 Mar 2025 12:13 AM
Did it work?
Message posted on 22 Mar 2025 07:24 AM
@Saarathy multiple reports showing Asus routers work on Sky lines when set up properly. To give any detail thoughforum members need to know if you are in the UK or Ireland and whether you have a full fibre or partial fibre connection.
Message posted on 22 Mar 2025 11:47 AM
Hi, I have full fibre broadband and in Ireland
Message posted on 22 Mar 2025 12:02 PM
Then any router will work as Ireland uses PPPoE
Nevertheless asus rt ax routers and zenwifi router/mesh setup are a favourite here
You need to set up the router as a pppoe connection and enter
Username anything@skydsl
Password anything
Then you enable vlan id and set the value to 10
Message posted on 20 May 2025 09:56 PM
@Chrisee - could you possibly help me with some info, i am looking to have full fibre installed with sky as the isp, i am looking to connect directly to ONT via a netgear nighthawk RAX70. I live in Northern Ireland, I assume this come under the UK authentication methods but i am not certain, are you aware of this?
any help would be appreciated
Would you be able to advise of the steps i need to take to configure my Nighthawk to authenticate with Sky and any details i need to enter into the router and where if possible
Many thanks in advance!
Message posted on 20 May 2025 10:01 PM
hi folks - apologies i meant to ask this above question of all, so anyone that can help me! thank you!
Message posted on 20 May 2025 10:28 PM
This is the rax router compatability and firmware requirements
It looks like the model below and above the rax70 support the client identifier option 61 required for authentication in the uk
RAX40 |
V1.0.3.62 and above |
RAX80 |
V1.0.3.88 and above |
There is a possibility that it may work using dhcpv6 prefix delegation which works on 80% of exchanges
But usually we advise the asus wifi 6 routers instead
Message posted on 20 May 2025 10:29 PM
@Stephen_J Sky use Openreach in Northern Ireland so the set up is the same as the rest of the ghe UK. Netgear routers normally support both Sky's older method of authentication which uses DHCPv4 Option 61 or the newer method of DHCPv6 PD which most but not all exchange equipment supports. There are should be a number of walk throughs on the forum if you search.
Hope thst helps9
