Discussion topic: Apps wont load on my andriod phone on wifi.
This message was authored by Drew2070 This message was authored by: Drew2070
Apps wont load on my andriod phone on wifi. Bbc news app wiil not work unless i switch to 4g. It's really frustrating that so many apps do not work on wifi.
Ring, hive, bbc etc
This message was authored by Paul276 This message was authored by: Paul276
Re: Apps wont load on my andriod phone on wifi.
Same here
@Drew2070 @Paul276
You may need to disable Sky Shield
I am NOT a Sky Employee
Drew2070
Hi James
Thank you for the advice but I've checked my sky shield and it is not switch on.  I'm at a loss to why this is now happening.
Hi @Drew2070 Please post your router stats
https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717/jump...
Drew2070
@Drew2070
Real odd one, your stats suggest everything is fine.
Have you tried changing the DNS servers on your phone?
Drew2070
No - They are set to the recomended automatic setting
@Drew2070
I would try using different DNS as a test. Try 1.1.1.1
There ia no option to show statistics, it says there is, but there isnt.
