Discussion topic: Apps don't load on phone
Message posted on
14 Mar 2024
11:13 AM
- last edited:
14 Mar 2024
11:39 AM
by
Kelsingra
Recently had fibre. All tests on app are good but a lot of apps on my phones won't load. It's as thought the wi fi is slow but the tests show it's not ?? Tried re booting it. No Joy. Any advice welcome.
Moderator note: Changed title to reflect topic more.
Message posted on 14 Mar 2024 11:24 AM
Re: Xx
@Juliannn Are you just new to Sky?
Message posted on 14 Mar 2024 11:26 AM
Re: Xx
That sounds like a Sky Shield issue to me, have you tried disabling it?
Message posted on 14 Mar 2024 11:42 AM
Re: Apps don't load on phone
I am not new to sky. This problem has only come about since I've had fibre. I'm having to use 4g which is quicker.
Message posted on 14 Mar 2024 11:45 AM
@Juliannn I would check Sky broadband sheild to make sure it has not re-set to the default of PG13.
Message posted on 14 Mar 2024 11:53 AM
Seems to work better with broadband shield disabled. But I need to have it on to protect what my children can watch ??
Message posted on 14 Mar 2024 11:56 AM
@Juliannn Have you tried all of the settings to see if one of them stick and still does what it is supposed to do.
