23 Jul 2024 07:47 PM
Hi there!
I'm in Dublin and I just moved to Sky broadband from Virgin Media. It appears I can't stream Irish radio stations on Apple Music since the change over (UK stations work fine).
On iOS, when clicking play on the station the app tries to load it but reverts to the previous selection a second after.
When I ask Siri to play, it tries but then says 'That station isn't available for your current location'.
I've tested my IP address on iplocation.net and it's showing as Ireland.
Is there a setting I need to change in my Hub to update the location?
Thanks!
24 Jul 2024 06:57 AM
Posted by a Superuser, not a Sky employee. Find out more@sfhaayun services use various ways of determining location and while some use tge IP4 address not all do. There are no lcation settings on your hub so nothing you can change.
You mayvwantvto piwer down your hub for 60 minutes as thstvdhould h=give you a different IP4 address which might work.
