Discussion topic: Anyone else experiencing slow downloads?
This message was authored by: DCrilly
Just noticed this tonight while downloading a game,  Hub is connected at the typical 549900 kbps, but downloads are capped at 10mb/s, usually in the 38-40 range.  Speedtest.com has dropped from 500Mbps to 80Mpbs but the sky speed test appears normal.  Latency/ping appears fine.
Anyone else?
Re: Anyone else experiencing slow downloads?
@DCrilly
Are you downloading over ethernet or WiFi? Have you tried via ethernet?
I am NOT a Sky Employee
