31
This discussion topic has been answered Discussion topic: Any way to tell if sky use openreach or cityfibre
This message was authored by: Batch
Long q short: as per title!
BT contract has expired. Sky offer through mysky is so much cheaper for full fiber 500 makes me wonder if the are using cityfiber.
Issue with cityfiber is that they wanted to dig up the drive, whereas openreach have pre existing  ducting that they used.
If sky turned it to be cityfiber I'd just cancel the order, but it would be much easier to know beforehand.
I will of course see if BT can get closer to sky's prices in the meantime.
This message was authored by: cookiemonsteruk Answer
Re: Any way to tell if sky use openreach or cityfibre
@Batch
The use of One Touch switching is far more convenient than tasking cityfibre to dig up the footpaths etc,  i think the main point of cityfibre partner is to reach areas openreach don't plan on upgrading to fttp
@Batch See if openreach have Fibre available to your address using there checker. If so, then have a look at what ISP's will supply to you!
Fibre Checker
Avatar for Batch
Level 3 icon
Thanks. I have openreach/BT fttp already. Cityfibre dug the street up 2 years ago so both are available. Given that, which will they use? After initially choosing a cityfibre isp I ended up cancelling because city fibre wanted to dig up a shared drive and said they couldn't use openreach ducting. I don't want this again!
@Batch If you have OR FTTP already installed into your home, up and working, not sure if sky would even contemplate using a CF fibre connection when it is sitting out on the road not even connected. Have you asked the question directly to sky.
If you are doing this all as a move provider then it just may be simplar to ask the question. Moving from and too a sky connection on an existing OR system is far easier for sure.
@Batch
If this is just upgrading speed on an existing openreach fttp connection sky would likely just use the existing connection
Avatar for Batch
Level 3 icon
Switch from bt->sky
Same speed.
Hopefully they go with what's there, but I guess order and cancel it it's switched to cityfibre!
@Batch Then i would expect a straight deal from sky, use all the existing as it is, take over the line from your current provider and sky organise it all, new hub sent to you, activation date for going live, and a straight out old hub, in new hub and off you go.....
That is how it should work, none off this faffing about with CF that is not at your home, one thing though, sky will not entertain using price off one against the other, so make a decission and stick to it.
@Batch
Avatar for Batch
Level 3 icon
Thanks. Sky offer is already really good so no haggling from me with them
@Batch Got it, just make your mind up with regards to what you have existing Router and any smart wireless you have as EE/BT side, to what you need to get from sky, can be a little bit off a miss concept in looking one against the other....
Avatar for Batch
Level 3 icon
Thanks all. Very much appreciated
This message was authored by: Deb3000
I would suspect Sky will go with whatever is cheapest and easiest.  That is, if you have OR infrastructure already in place then they'll go with that.  After all, as the will have to pay for the installation work, that would make the most economic sense.
My problem is I still don't have FTTP installed but both OR and CF infrastructure are avaiable.  I too would like to hear if anyone knows how to get Sky to commit to what they are going to use before the order goes through?
@Deb3000 That's a call to sky for sure to find that out, how is you current connection on the copper, pole or underground, and where is OR fibre sitting at present. Not always clear but OR can jump the gun and not all the ISP's have the needed/necessary exchange equipment up and ready to go. OR Fibre or BTW fibre checker's get you somewhere near but if sky say you can have it when you look at the offer's pay attention to the Up/Down speed's, symmetrical OR DO NOT DO at present!
Fibre Checker
BT Broadband
Ah, the symmetrical speed bit is a good call.  Didn't think of that.  I'll have another look.
Edit: Yeah, speeds for the 300 package are almost the same, i.e. symmetrical.  That suggests CF.
@Deb3000 That would be my thought also!
