Discussion topic: An not connect to TV
This message was authored by: ThebigACL
Had an issue with connection to my tv since having sky
Re: An not connect to TV
@ThebigACL if oother devices connect properly but you cznnot connect your TV unplug the power from the TV until the power led goes out then re-start it this should make it reboot which usually means it will be possible to connect it to your Sky hub
