Discussion topic: Amber light on daily and no broadband signal
This message was authored by: Andrewcowan840
Dropping broadband daily with amber middle light showing 70%
"Netflix not available"
sky or Netflix with the timer logo going in circles daily.
i do the WiFi and broadband check and it tells me all is good yet the TV tells me no broadband signal?!!!
Re: Amber light on daily and no broadband signal
@Andrewcowan840
Could you post your hub stats
Also run the service checker on your my sky app using 4g/5g mobile data
