Discussion topic: Alexa 1st gen will not connect to sky max
Message posted on 27 Apr 2025 08:51 AM
Cannot connect Alexa 1st gen to sky max and cannot get onto advance settings on white sky max router
Message posted on 27 Apr 2025 09:33 AM
Re: Alexa 1st gen will not connect to sky max
@Ronald20 Is this device looking for the frequency of 2.4 rather than 5.0 on the Wi-Fi. Might be you need to do a temp disable of the 5.0GHz and try connect the device then turn it back on to see if it stays connected.
Message posted on 27 Apr 2025 09:50 AM
But cannot get onto the sky max settings advance to change the WiFi settings
Message posted on 27 Apr 2025 10:00 AM
@Ronald20 Are you trying to do this via the web interface on the router and not the settings that are found on the Sky app?
