Discussion topic: Adaptor with fibre broadband plug
This message was authored by: jac26
I have just had fibre broadband installed.  I did not realise that both sockets  would be used for the routers.  Can I put one of them in an adapter or do they need to be separate in the plugs.
Re: Adaptor with fibre broadband plug
@jac26
If you mean the power sockets for the fibre ont and the sky router then yes you can put one or both into a multisocket adapter
