Discussion topic: Access to Sky Hub router settings via 192.168.0.1 is denied - Authorisation required
Message posted on 28 Jan 2025 04:24 PM
I can access the Sky Hub router information page using 192.168.0.1 but I cannot access any of the settings. If i click on any of the menu or top bar items i just get:
Authorisation Required by http://192.168.0.1 Your connection to this site is not secure
Please advise
Message posted on 28 Jan 2025 05:07 PM
Re: Access to Sky Hub router settings via 192.168.0.1 is denied - Authorisation required
Can you post a screenshot?
Message posted on 29 Jan 2025 02:37 PM
As already requested, a screenshot would be helpful if you can.
The error message you are seeing, and the IP address that you have included in your post, do make me wonder if this is a "browser" issue rather than a sky hub issue.
Which browser are you using? (Chrome/Edge/Firefox/Opera/Samsung/etc)
Most browsers nowadays will only allow connections to sites using HTTPS. The IP address from your post is using HTTP.
It is likely the HTTP address that is causing you to see this warning message.
Is there an option shown in your browser when trying to access the sky hub portal, for something like "continue anyway" or "ignore error" or "advanced" or "trust this website"?
You should be able to get your browser to continue connecting to the sky hub portal and ignore the fact the connection is only HTTP.
