Discussion topic: Access 2.4ghz wifi
This message was authored by: Han10
Access 2.4ghz wifi
I need to be able to access 2.4ghz aswell as the 5 to connect some of my devices but I can't see how or if I can access this?
Re: Access 2.4ghz wifi
@Han10  black or white router from Sky?
@Han10
By default a Q Hub, Sky Broadband Hub or Max Hub will be broadcasting the same SSID on both 2.4Ghz and 5Ghz simultaneously.
Avatar for Han10
Ots a White router
Avatar for Han10
@Highlinder it's a white router
@Han10
In the My Sky app you can disable the 5ghz band temporarily if you want to connect smart devices.
I am NOT a Sky Employee
Avatar for Han10
Where do I find how to disable it in the app please?
@Han10
Under your hub settings then WiFi. I cant say exactly as I do not have the Sky Max hub.
