Discussion topic: Absolute 0 Internet connection
This message was authored by Owen2021 This message was authored by: Owen2021
Thought the whole day my Wifi has been off, I’ve personally tried rebooting the box and following the instruction from msftconnect and nothing makes a difference the whole day literally no internet at all, yet again in this situation as sky can never sort themselves out
Re: Absolute 0 Internet connection
@Owen2021 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
ISPs don't get to resolve issues with the Openreach network, and Openreach don't work on individual domestic faults over weekends.  If you log the problem with Sky today, the Openreach target time to fix will be by midnight on Tuesday.
Owen2021
“Sorry, no address is associated with your account” Although I ran the test with same account last night 10/10
Owen2021
Like I don’t want to sound like a **bleep** or be rude but it’s extremely frustrating because the amount of times we’ve had issues with sky is absolute pathetic and for it to be down the whole day is just really irritating
Owen2021
This message was authored by adwarduk This message was authored by: adwarduk
@Owen2021 - If you have the myskyapp on your phone (and a data connection) try running a connection test on there.  If it finds something it'll give you directions on how to get help etc.  Should rule out a major (i.e line fully broken issue) If it doesn't find anything you may need to call support.   Out of interest which sky router have you got?
Sky stream, sky ultrafast with WiFi Max inc pods. BT halo3+ for none home usage. All round nerd 邏
Owen2021
Sky Q Hub
@Owen2021 - I'm assuming all 3 lights on the front of the hub are green?  (silly question apologies). I think the myskyapp test is the only option other than support,  if thats shows no service on the account or similar thats definitely a call to sky I'm afraid.  Apologies I can't help much more.
Owen2021
Middle light has been orange since this morning
@Owen2021 - Thats a line issue,  it can't connect to the exchange so definitely a call to sky I'm afraid.  Do you get dial-tone on the line.   The reason I ask the dial-tone question is I have known it when openreach engineers (mainly the sub-contractors) have been working on another line and caused an issue on a different customers accidentally and it normally results in either no dial-tone or other weird issue like not being able to make an outbound call or an inbound call getting a busy tone when its not busy.
@Owen2021
If you cannot call sky get back to us so that we can escalate your case
Owen2021
Alright will give them a call
@adwarduk
In case you were wondering your post has been moved to our hidden forums to keep an eye on . If you see a red notification and can't find it thats the reason
@cookiemonsteruk - thats fine mate,  it was just very weird and the timing seemed to much of a coincidence.  I've left the hub as is for now and the app,  tbh I know what will happen I update the app to match it will either fail or i'll have to re-connect all the devices as the wps keys will change.  Be interesting to see if it changes back to match the app or whats in the app updates I'll keep an eye on that.   Happy for anyone to PM me if they need more info etc.  I've screen capped both as well 🙂
