Discussion topic: 900mbps no chance
Message posted on 16 Oct 2025 06:12 PM
900mbps no chance
So I have the 900mb and guess what I get just under 250 up and down... but the sky checker says all is fine... anyone?
Message posted on 16 Oct 2025 06:20 PM
Re: 900mbps no chance
How far are you from the router? How many walls are there between you and the router? Does your wifi device support wifi 6 with 2x2 MIMO?
The best real-world speeds of WiFi 6 with 2x2 MIMO typically reach around 600 to 900 Mbps under good conditions.
This speed will drop quickly as you move away from the router, place a wall between you and the router, and introduce radio noise, such as microwaves and neighbours' Wi-Fi.
Message posted on 16 Oct 2025 06:57 PM
Hey thanks for the advice. I'm sat basically on top of it. Using a Samsung A13 and it's very patchy sometimes I get 30 up and down, yet sky insist it's ok
Message posted on 17 Oct 2025 12:09 PM
Ok as an entry level phone the A13 supports 802.11ac 2x2 MIMO (WiFi 5) so you should expect real-world performance up to about 500Mbit/s. It supports WPA3 so there should be no issues connecting to a new white sky router.
Try using the service checker, what does it say?
https://www.sky.com/servicechecker/broadband
https://www.sky.com/servicechecker/broadband/checks
https://www.sky.com/servicechecker/wifi/checks
Message posted on 17 Oct 2025 12:19 PM
Also make sure you are connected to the SSID of the router and are not using mobile data or a neighbour's Wi-Fi.
