21 Nov 2024 01:06 PM
Hi All,
Sky Ultrafast broadband and getting 500 down to the hub but only a max of 230 over Wifi.
I've checked drivers, come off the VPN, get the same result on my laptop and PC.
Is there anything settings on the router I can check?
When I check the connection I can see it's using 5 Ghz but protocol Wifi 5?
Cheers
21 Nov 2024 01:15 PM
That would be correct if your laptop hardware doesn't support WiFi 6.
21 Nov 2024 01:23 PM
The wifi card is WIFI-6
MediaTek Wi-Fi 6 MT7902LEN
21 Nov 2024 01:24 PM
But in Windows;
SSID: Sxxxxxxxxxxxxxxxxx
Protocol: Wi-Fi 5 (802.11ac)
Security type: WPA2-Personal
Manufacturer: MediaTek, Inc.
Description: MediaTek Wi-Fi 6 MT7902LEN Wireless LAN Card
Driver version: 3.4.0.1063
Network band (channel): 5 GHz (36)
Aggregated link speed (Receive/Transmit): 433/433 (Mbps)
IPv4 address:xxxxxxxx
IPv4 default gateway: xxxxxxxxxxx
IPv4 DNS servers:xxxxxxxxxxx (Unencrypted)
Physical address (MAC): xxxxxxxxxxxxxxxxxxxxxxx
21 Nov 2024 01:25 PM
White or black Sky Hub?
21 Nov 2024 01:29 PM
It's the black hub
21 Nov 2024 01:31 PM - last edited: 21 Nov 2024 01:37 PM
Only the white Max Hub (released in 2023) is WiFi 6 (802.11ax) and does WPA3.
Presumably yours is a Sky Broadband Hub from 2019: that's WiFi 5 (802.11ac) and WPA2-PSK
21 Nov 2024 01:36 PM
So ideally I need to upgrade my router to take full advantage of the speeds down to the hub (ie WiFi 6) ?
21 Nov 2024 01:39 PM
That would at least put both source and client on the same hardware level. Whether it's necessary is debatable: does anything you do on the laptop actually need more bandwidth?
21 Nov 2024 02:15 PM
I suppose it would be nice to get the speed im paying for.
May look into getting another router then
21 Nov 2024 02:36 PM
You're paying for speed to the Hub, not beyond it. Realistically only huge games updates actually benefit from anything more than about 30Mbs (which is what's required for UHD streaming)
Sky would happily offer you their Max Hub for an additional monthly subscription.
21 Nov 2024 02:47 PM
So what's preventing from getting similar speeds on WiFi using WiFi 6? It's not a distance/signal issue as I've tested right next to it.
21 Nov 2024 02:58 PM - last edited: 21 Nov 2024 03:00 PM
There's reams of discussion online about theoretical Vs real world wireless speed if you really want to get into it: personally I don't bother as long as the service being delivered over WiFi works.
If you want guaranteed maximum speed without multiple (and fluctuating) external variables, ethernet cable is the way to go.
21 Nov 2024 03:01 PM - last edited: 21 Nov 2024 03:02 PM
I'd add that my 500Mbs BT FTTP typically 'tests' as about 200Mbs on my phone, 300Mbs on a WiFi 6 laptop (but the router is WiFi 5) and 500Mbs+ on ethernet. We're an isolated house though with very little local wireless interference.
12 Dec 2024 03:40 PM
I measured speed to my black router by hardwire Ethernet cable into back of router and then direct to laptop. Should be getting minimum of 600mb to router but only getting 493 maximum seems around 440mb after trying several measurements. Anyone any ideas please
