This discussion topic has been answered Discussion topic: 2gb channel
Message posted on 23 Aug 2025 10:51 AM
Hi.
just asking for some advice please.. bit of a novice here...
Apparently I need to split my broadband so that I can identify the 2Gb channel and use it for my ring doorbell and other devices that only support 2G.
is this a relatively easy process? I've read elsewhere that I need to go into the router admin and there is an option to split the channels.. and then once done I have to rename the channels such as xxx-2G and xxx-5G, so they can be seen and attached to.
Assuming the above is correct, can I just name the new 2G channel and leave the old one as it was? If I rename the existing one as well I'll have to reconnect all my current devices.. which is a pain.
Any thoughts on this process at all gratefully received.
Message posted on 23 Aug 2025 10:57 AM
For the black router the process you mentioned is correct . For the white router you temporarily disable the 5ghz.
Both processes are shown below
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
Message posted on 23 Aug 2025 05:26 PM - last edited: 23 Aug 2025 05:27 PM
Re: 2gb channel
To avoid confusion, it's 2.4Ghz (a WiFi frequency) rather than 2Gb (a data volume / speed) or 2G (an obsolete cellular technology)
Message posted on 23 Aug 2025 09:24 PM
Re: 2gb channel
Thanks so much for the clarification. Yes, of course it's GHz rather than Gb 🤦🏻
Message posted on 23 Aug 2025 09:28 PM
Re: 2gb channel
Hi there,
Thank you very much for the info and the link - much appreciated👍
