Discussion topic: 2 geeen lights 1 amber and no light on internet
This message was authored by: Dbell1
I have a green light on the power and WiFi no light on the internet and orange on voice. Nothing is working via WiFi - tested on app and said everything ok in area? Can any advise please - been like this for two hours
Re: 2 geeen lights 1 amber and no light on internet
@Dbell1
This explains the lights on the hubs:
Try running the line test here:
If this is of no help give Sky a call to report it to them.
Avatar for Dbell1
Thank you
This message was authored by: Liliko
Got same issue, checked all and still nothing. Problem on sky side
This message was authored by: PRalph
Same here in Thanet, Kent. Been diagnosing as showing a fault but then it's saying its all fine ... only the 2 lights on
