Discussion topic: 2.4hz not being discovered by devices
This message was authored by: Luke123--
One of my devices won't pick up 5hz wi-fi. Software provider mentions I need to switch to channel 36 on the 5hz. I read the sky hub max cannot do this. I the disabled the 5hz wi-fi leaving the 2.4Hz still ticked but no devices is finding the 2.4Hz. Any suggestions?
Re: 2.4hz not being discovered by devices
@Luke123-- What is the device with the issue?
Avatar for Luke123--
So, no device is picking up the 2.4Hz, if I disable the 5hz. I have Laptop. Phone. PC. TV.
The 5Hz issue is on some software / motion sensors used on the PC.
@Luke123-- So you are doing this connected Ethernet to the hub at present?
It's a new build. I've got port 4 WAN going to an open reach box.
Port 3 goes to Tado Central heating dongle.
Port 2 goes upstairs ethernet slot
Port 1 goes to downstairs ethernet slot.
Only the downstairs one is used on PS5.
Everything typical runs of the 5Hz signal on wifi
@Luke123-- The sky max hub transmits the 2.4Ghz and the 5Ghz signal using the same name jim12345 as an example.   The devices connect to either frequency as required, If a 5Ghz device it will prefer to try and use the 5, if it can't it will try to fall back on the 2.4, so when you turn off the 5Ghz band then reset the hub by powering off. When powered back on and because you have disabled the 5Ghz, all the wireless wi-fi devices should connect as before but now on the lower frequency....
Are you saying that this is not happening they DO NOT reconnect?
Edit:- you also need to go read your very first opening post, what you have said is complete utter rubbish, there is NO channel 36 on a 2.4Ghz band, 1 through 15 only for 2.4Ghz, 5Ghz starts at Channel 32 onwards, think not adjustable on a max hub, but then again it is all stupid mobile app based and may only allow an auto so it could be anywhere unless your app tells you it's current setting.
You could use a free Wi-Fi analyser on your mobile, if so would recommend you look at Netspot to do so, good at showing what is going on....
My first message states 'Software provider mentions I need to switch to channel 36 on the 5hz'.
I'm trying to trouble shoot the software on 2.4Hz.
"Are you saying that this is not happening they DO NOT reconnect?" - yes, nothing is picking the WiFi when I disable the 5Hz.
@Luke123-- Then you need to go look at the devices why they are not connecting or seeing the 2.4Ghz....
In case this is just the 2.4Ghz devices thet you are trying to connect, you may wish to also fold back the WPA mode on the Sky Max hub also!
Yes, that's why I'm asking for suggestions. I don't know why they wouldn't connect.
@Luke123-- You said NO devices are finding 2.4Ghz, that means all your devices, phones, laptops, pc's tv's......
