Discussion topic: 2.4ghz doorbell, can I connect to the hub
Message posted on 08 Feb 2025 04:07 PM
Message posted on 08 Feb 2025 04:17 PM
Re: 2.4ghz doorbell, can I connect to the hub
@JasonHill what colour is your Sky hub?
Message posted on 08 Feb 2025 04:21 PM
Message posted on 08 Feb 2025 04:27 PM
@JasonHill first point is to reducec security level for the hub in the My Sky app from wpa3-t to wpa2 as that might sort it for you. If it doesnt turn off the 5GHz band in the same advanced settings area in the app, network the doorbell then turn thec5GHz band back on.
Message posted on 08 Feb 2025 04:29 PM
