Discussion topic: 2.4 instead of 5g for in home security camera
This message was authored by: Ghhfgv
Message posted on 27 Dec 2025 11:49 PM
I am trying to set up a camera but my WiFi won't allow it, how do I switch it to 2.4 instead of 5g for the camera to be set up?
Find out more
Message posted on 28 Dec 2025 07:54 AM
Re: 2.4 instead of 5g for in home security camera
@Ghhfgv all Sky hubs transmit a dualband SSID so use both 2.4GHz and 5GHz. The issue is some cheap WiFi chips have an issue connecting to acdualband SSID. If you have a black Sky hub you can if you want split the two bands as explained here Split Sky WiFi bands
You cannot do this on the white hubs as that breaks the newer WiFi6 standard thry offer. Instead using the hub's advanced settings in the My Sky app you turn off the 5GHz band, connect the cameras and then turn the 5GHz band back on. Modt devices remain connected.
