Discussion topic: 2.16mbps speed when it even registers any speed at all. Well over 24 hours of this now
This message was authored by bennett17 This message was authored by: bennett17
 I have unplugged everything for over 10 mins I have held the reset buttons for 10 seconds ect ect. Having no joy with it, anyone help please
bennett17
Re: 2.16mbps speed when it even registers any speed at all. Well over 24 hours of this now
White smiley face power and wireless button white also. I'm all out of ideas other than go too another provider as it isn't good at the best of times
This message was authored by JimM1 This message was authored by: JimM1
@bennett17 Are you running the speed test on 4G?
Lights on your Sky hub explained | Sky Help | Sky.com
And if you have the sky hub, its time to request a replacement.
This message was authored by Ryan+H This message was authored by: Ryan+H
You're not even connected to WiFi, you're connected via 4G so you're not testing Sky WiFi
@bennett17
As others have said you were testing your 4G speed not your WiFi speed.
Additionally if you still have a router thats got a smiley face on it then you wont be getting very fast WiFi speeds as that router only supports 2.4ghz WiFi.
I am NOT a Sky Employee
