1
Discussion topic: ÇCTV camera but need to be 2.4ghz..
This message was authored by Dave63 This message was authored by: Dave63
Hi, I have just installed a CCTV camera and now found out it only works on 2.4ghz.
I assume my sky Q hub is 5G.
I have read you can alter the hub settings to do both for devices that need a different setting but not sure how to.
                    Many thanks ....Dave.
This message was authored by Skull+Treaty This message was authored by: Skull+Treaty Answer
Re: ÇCTV camera but need to be 2.4ghz..
You can split the Wi-Fi bands @Dave63 ,
to do this simply follow this User Guide
"Sometimes, the only choices you have are bad ones, but you still have to choose"
