Discussion topic: small picture on really programme on sky glass
Message posted on 10 Nov 2021 09:02 PM
Hi all has any one got this problem, please help needed onlystartedto happen todayThis only happens on 1 channel the channel on sky glass is called really the picture is clear BUT all around the edge of the screen there is a black thick line that makes the picture small any ideas please many thanks
Message posted on 10 Nov 2021 09:05 PM
Re: small picture on really programme on sky glass
Any chance you can upload a image?
Message posted on 10 Nov 2021 09:11 PM
@isaacs147 wrote:Hi all has any one got this problem, please help needed onlystartedto happen todayThis only happens on 1 channel the channel on sky glass is called really the picture is clear BUT all around the edge of the screen there is a black thick line that makes the picture small any ideas please many thanks
It could be the programe they are showing was made this way?
Message posted on 10 Nov 2021 09:13 PM
so sorry no i am a pensioner and not very savvy on that subject of downloading the image the black line line is about 1 to 2inches wide all the way around the edge of the picture screen thanks for your reply
Message posted on 10 Nov 2021 09:18 PM
okay but the same programe on the sky glass tv in my front room is fine this only happens on the tv in the kitchen that my wife watches it is a 14 inch bush tv only 12 months old we also have a puck in the kitchen which i have reset but still same problem thanks for your help
Message posted on 10 Nov 2021 09:23 PM
@isaacs147 wrote:okay but the same programe on the sky glass tv in my front room is fine this only happens on the tv in the kitchen that my wife watches it is a 14 inch bush tv only 12 months old we also have a puck in the kitchen which i have reset but still same problem thanks for your help
In that case it's likely to be a setting within your Kitchen TV's menu and not necessarily the puck.
Message posted on 10 Nov 2021 09:35 PM
thanks for your reply but have tried all picture settings on the remote in kitchen tv tried zoom tried 1all picture ratios but will not work thanks for you suggestions
Message posted on 10 Nov 2021 09:37 PM
Do you mean on the sky remote or the remote for the tv?
Message posted on 10 Nov 2021 09:44 PM - last edited: 10 Nov 2021 09:55 PM
@isaacs147 Is this on ALL programmes on the Really channel, or just one specific programme? This sounds like a programme in 4:3 aspect ratio being broadcast in a 16:9 format (or visa versa).
Explained here ::https://chetdavis.typepad.com/chet-davis/2009/11/when-your-video-becomes-a-postage-stamp-or-window-b...
Message posted on 10 Nov 2021 09:49 PM
great solution thats the words i was trying to use that is exactly what it looks like it only happens on 1 channel the channel is called Really has homes under the hammer on it its great that you tried to solve it for me many many thanks
Message posted on 10 Nov 2021 09:50 PM
on both thanks
