Discussion topic: lost Sky Box power cable in house move
Message posted on 05 May 2021 03:58 PM
Hi All, My sister has recently moved house and in the move has misplaced her power cable, the engineer has been out to set up but has said the power cable he has left will need to be returned, is there a way to replace the cable?
Message posted on 06 May 2021 11:23 AM - last edited: 06 May 2021 11:24 AM
@MountainFamily wrote:Hi All, Thanks for your reply, the engineer did take it out of new set up box hence im wanting itback, not sure when he will catch them at home to get it though!
My Dad was there he said it was a yellow connector so not the figure 8 mentioned.
Fingers crossed the engineer will forget!
interesting - the standard colours for SKY cables are Blue for the power cable, Pink for the HDMI cable & yellow for ethernet (which not everyone uses)
As I say those are the standard SKY colours but it may not have been a SKY one I guess
Message posted on 05 May 2021 04:06 PM
Re: lost Sky Box power cable in house move
Power cable for the Sky Q box? Main box or mini box?
What version of box is it? Did it have an external power brick?
If the engineer has left you with one then presumably it is working? You won't need to return it until you return the Q box whenever you decide to leave Sky.
Message posted on 05 May 2021 04:11 PM - last edited: 05 May 2021 04:11 PM
They probably nicked it from another carton on the van, which is why they want it back ; )
The tricky one is the power supply for the v2 box with the external transformer, as that's not a standard connection type.
Message posted on 05 May 2021 04:42 PM - last edited: 05 May 2021 04:47 PM
hi @MountainFamily if the box does not have a separate power supply, as the others have indicated, then the boxes use a standard 'C7' figure of 8 connector. ( BTW even the external power supply version may also use the same C7 connector from the mains to the power supply unit - but I don't know)
Standard power cables with C7 pugs are available, in many lengths, from many sources and are not expensive .
Personally I would not think it would be a cost effective use of an engineers time to chase up return of such a cable but who knows
Message posted on 05 May 2021 05:02 PM
Doubt the engineer will come back for it. He could surprise us though.
Message posted on 06 May 2021 11:12 AM
Message posted on 06 May 2021 11:14 AM
@MountainFamily Just dont answer the door if he comes back 😉
Message posted on 06 May 2021 11:26 AM
@nigea99 we have a yellow connector in the back of our main box- not ethernet, i dont think its a power cable though, i have left them to it for now!
