Discussion topic: itv hub on sky glass
Message posted on 30 Dec 2021 04:26 PM
Re: itv hub on sky glass
Itv not working on glass works fine on my other devices any advise please
Message posted on 30 Dec 2021 04:33 PM
@TONI88 wrote:Itv not working on glass works fine on my other devices any advise please
Stating the bleedin' obvious, but have you turned it off and on again?
Message posted on 30 Dec 2021 04:35 PM
Yes I have tried that and tried logging in and out.
It is the hub that is not working neither is prime.
Both of which work fine on all my other devices
Message posted on 30 Dec 2021 04:38 PM
@TONI88 wrote:Yes I have tried that and tried logging in and out.
Don't know what else to suggest then I'm afraid. These Glass TV's seem to like to do random things to annoy people. This is probably one of those.
Message posted on 03 Jan 2022 11:05 PM
Yes it's terrible. I plugged my Sky q box back in and around the same episode of coronation Street on ITV hub and the quality was much better with virtually no motion judder.
The fast forwarding and rewinding is also easier on the q box as you have dedicated buttons and you can see the picture moving and see where you are up to.
Message posted on 03 Jan 2022 11:31 PM
@Doubleyougee wrote:Yes it's terrible. I plugged my Sky q box back in and around the same episode of coronation Street on ITV hub and the quality was much better with virtually no motion judder.
Sky Glass FF/RW does not show where you are other then the time?
Message posted on 04 Jan 2022 07:04 AM
No not on Glass. You use the right or left buttons to select fast forward or rewind and then press the middle button to select the speed but the only thing that moves is the time the picture does not move so you don't know where you are rewinding to.
On sky q because the remote control has dedicated forward and back buttons it is a lot easier but the picture also moves fast so that you can see whereabouts you are forwarding or rewinding to.
Message posted on 04 Jan 2022 07:11 AM
@Doubleyougee that is because you have a local disc with Q that you can control, with Glass it is a remote stream so you are jumping to specific points in that stream as there are no trick play options..
Assume you very recently got Glass as your Q boxes should stop working once you activate Glass but can still work for a limited time.
Message posted on 04 Jan 2022 10:17 AM - last edited: 04 Jan 2022 10:17 AM
@Chrisee wrote:@Doubleyougee that is because you have a local disc with Q that you can control, with Glass it is a remote stream so you are jumping to specific points in that stream as there are no trick play options..
Other streaming services allow you to see where you are when you FF/RW.
Message posted on 10 Jan 2022 11:05 AM
ITV Hub is nightmare - had to create an account in sky hub and then it forgets where you are on Sky glass - have reverted to watching on my ipad!!!!!!
Message posted on 10 Jan 2022 11:08 AM
had glass 10 days now and very frustrated with things like this - i will give it another week but then probabbly returning to sky Q
Message posted on 10 Jan 2022 11:17 AM
@bobalong You shouldn't keep being prompted for credentials for any of the apps on Glass. Does this happen for any of the other apps?
Message posted on 10 Jan 2022 11:52 AM
We've arranged to send Glass back
The television itself seems pretty good from the sound is very good especially for a television but I cannot cope with the streaming services literally just does not work properly. The playlist is all out of sync and all over the place and ITV hub is just a joke. If they have incorporated a hard drive into the sky glass this would work very well as I appreciate that the dish probably won't be around in another 10 years.
Been out and bought a new Samsung TV and reverted back to Sky q and we are much happier.
Message posted on 10 Jan 2022 12:21 PM
@Doubleyougee wrote:We've arranged to send Glass back
Good luck with the Samsung. Most TV problems Sky Q has is with a Samsung TV with the One Connect.
Message posted on 10 Jan 2022 12:23 PM
Not all Samsung TVs have the One Connect box. Not all Samsung TVs have problems with Sky Q.
