This discussion topic is read only Discussion topic: Wire cable cover
This message was authored by: Vickiness
Wire cable cover
The cover for my sky cable; where wall was drilled and cable ran through has nearly come off, what do I do?
Locked
Re: Wire cable cover
@Vickiness  Put it back on with some adhesive. Any decent DIY store should know what is needed.
This message was authored by: bob1234
@Vickiness  Put some sealant underneath it, the cable does  not go through it. I used "No more nails"  just because I had some, any sealer/glue will do.
Locked
