4
This discussion topic is read only This discussion topic has been answered Discussion topic: Will the AsusRT-AX86S work as a 3rd party router
This message was authored by: Simont12
Hi just upgraded to the gigafast and getting really poor speeds from the stardard router even through wired  have been looking at routers and this has come up with an Easter sale so wondered if it would work? Cheers
This message was authored by: cookiemonsteruk Answer
Re: Will the AsusRT-AX86S work as a 3rd party router
@Simont12
All the below will work with sky
Rt ax56u
Rt ax58u
Rt ax68u
Rt ax86u
Rt ax88u
Mine is the rt ax58u and would be the minimum spec due to adaptive qos which allows you to switch priortise
 between gaming, streaming, browsing etc via the asus router app
Locked
@Simont12
Not sure of the difference between rt ax86s and rt ax86u.  But the rt ax86u definately does with asus-merlin firmware. Probably best to call asus uk re the rt ax86s
Avatar for Simont12
@cookiemonsteruk
Hi what am I looking at as far as specs to see if it does?
The other I have looked at is the  Asus RT ax55 slightly cheaper
@Simont12
Rt ax56u
Rt ax58u
Rt ax68u
Rt ax86u
Rt ax88u
Avatar for Simont12
@cookiemonsteruk
Just so you know it does work got the router today put the wan to automatic and the dchp 61 appeard put the username in and boom it's off
Locked
