Discussion topic: Wifi Booster only has a green power light
Message posted on 18 Apr 2022 11:02 PM
My booster has been working perfectly for months then randomly stopped working. The power light is green but no other lights are on. I have tried resetting the booster but the light just goes red then turns green again. The model is SE210
Message posted on 19 Apr 2022 11:15 AM
Re: Wifi Booster only has a green power light
Hi @Helen1968..
Is it possible to try and connect the booster to your hub via ethernet as a temporary measure to see if it'll reconnect?
Message posted on 19 Apr 2022 08:59 PM
Just tried this, lights are still the same.
Message posted on 21 Apr 2022 09:55 AM
Sounds faulty then unfortunately, you'll need to request a replacement from Sky.
