This discussion topic is read only Discussion topic: Switching from now tv to sky
This message was authored by: subboff
Hi Everyone
I would like to switch my internet provider from now tv to sky as now tv do not offer a fibre to the home ultrafast service.
I would like to keep my existing phone number but whenever I try to sign up for the service it is rejected. Have spoken to sky rep and the problem seems to be that now tv and sky are connected in some way and it is impossible.
Has anyone else had the same issue or found a solution
Locked
Re: Switching from now tv to sky
@subboff
Not something the forum will be able to help with. Your best doing it over the phone
I am NOT a Sky Employee
Avatar for subboff
@jamesn123
Hi James
Thanks for your reply
I have spoken to sky on the phone but they said it can't be done which I find extraordinary as sky and now tv are linked together in some way.
Just wondered if anyone else had come across this problem and if so found a solution.
@subboff
If sky and now tv can't provide ultrafast then no other isp connected to openreach is likely to be able either  enter your full postal address in the database below and post the table for advice
@subboff wrote:
@jamesn123
That seems to be the source of the problem....
Avatar for subboff
It's not that FTTP is not avaliable it is just that sky can't transfer my number as I'm already with now tv. Sky say that it's like signing up to a package when you already have one !
My only other option is to go with BT , bit more expensive though.
Avatar for subboff
Avatar for subboff
I recall at least one other post recently reporting the same issue, so it does seem to be intrinsic to the overlap between NowTV Broadband and Sky Broadband (which are, hardware-wise at least, the same product).
Avatar for subboff
If Now TV did a FTTP package it would't be a problem I could just upgrade !!!
@subboff
Sky owns both businessess: I suspect the difference is largely to do with branding and marketing, just as NowTV is positioned not to erode Sky TV subscriptions.
Locked
