Discussion topic: Sonos issues
This message was authored by littlelucys This message was authored by: littlelucys
Sonos issues
I know this has been discussed to death but I still cannot work out how to solve our issue.  We have Sky Q and one mini.  We have various sonos products through the house.  We have an Asus router using BT FTTP so super fast broadband.
Following previous similar issues, we did have the main sky box and one of the sonos speakers connected by ethernet cable directly to the router (solved all problems) but for various reasons we have had to put them all back on wifi.  We have sep wifi for 2.4 and 5 if we need to split that.
Problem: sky works fine but Sonos keeps dropping out with error messages and devices disappearing.  This did not happen before we had sky Q.
Please tell me there is a solution!
Locked
This message was authored by Rhonny This message was authored by: Rhonny
Re: Sonos issues
@littlelucys
Can you definitely not plug one Sonos back into the router by ethernet? That would take all your speakers off your wifi completely and onto their own Sonosnet, which should cure the issue.
littlelucys
Re: Sonos issues
Sadly no. Different floors
Re: Sonos issues
@littlelucys
Your Sonos speakers might be experiencing a wifi clash that your Sky Q box isn't for some reason. On your router, try changing the 2.4ghz channel from its current number to 1, 6 or 11. See if one of those improves things.
If not, then get a Sonos Boost and plug it into your router. That is the equivalent of a speaker, and will take your Sonos speakers off the wifi onto Sonosnet. It works like a charm.
littlelucys
Re: Sonos issues
Thanks. Changing channels does not work (well not consistently).
I am aware than Boost will help but am reluctant to spend more money when the issue should surely be resolvable. I assume sky would not buy me this as it's their system thats causing the issues 😂
Re: Sonos issues
@littlelucys
Whilst Sky uses 2.4ghz to connect to a non-Sky router, as does Sonos, you could try instead changing the channel of Sky's 5ghz mesh just in case.
Go down to Settings but don't press Select. Instead type 0 0 1 Select to open the hidden menu. From there you can change the 5ghz channel. If it's 36, change it to 44, and press Confirm. Try that and see if that helps any better.
littlelucys
Re: Sonos issues
thanks, will give that a go.  For the record, last time we had this issue (when we first got sky Q and were using wifi) we were using a sky router and still had the issue.
Locked
