Discussion topic: SkyQ and Sonos interfering with each other
Message posted on 25 Mar 2021 01:55 PM
Re: SkyQ and Sonos interfering with each other
Yes - just one of your boxes needs to be on the ethernet. It then creates the SonosNet which al your Sonos kit will link to. You need to leave it connected to the router from then on. It that is not possible, consider buying a Sonos Boost which you connect to your ethernet and it does the same thing.
Note that the Move (and the new Roam) are wifi and bluetooth and do not appear on the SonosNet so they will link to whatever wifi band you have set them up with only.
Message posted on 25 Mar 2021 02:07 PM
Thanks @ChrisWil58 , but that's not the problem in my case. I only have one Wifi network, created by the Sky Q Router that I connect to. I do have my Sonos Beam connected by PowerLine to the router, so that should be creating the SonosNet mesh that you mentioned.
I suspect the problem is because the Sky Q kit also creates it's own Mesh network for all the Sky Q devices to talk to eachother. I didn't used to have the SonosNet mesh, and the problem was still there. I connected the Beam to ethernet to try to alleviate the problem, but it didn't help.
I just think that the Sonos networking does not work properly when there is a Sky Q mesh network involved. Something is probably on the same channel or frequency or something, and causing interference and stopping stuff working.
Message posted on 25 Mar 2021 02:10 PM
@Dunshavin wrote:Thanks @ChrisWil58 , but that's not the problem in my case. I only have one Wifi network, created by the Sky Q Router that I connect to. I do have my Sonos Beam connected by PowerLine to the router, so that should be creating the SonosNet mesh that you mentioned.
Why bother with Sonos Net when Sonos kit works perfectly fine with ordinary home WiFi.
Message posted on 25 Mar 2021 02:25 PM
I have an ASUS router, and Sky Q and Mini Q. Sky has it's own mesh, Sonos has it's own mesh. I have the ASUS XT8 controlling my wifi (wifi turned off in the router). Sonos Boost, and first XT8 are direct ethernet links to the router. I don't have an issue.
Have you contacted Sonos support. I have found them to be very capable and helpful, and even helped diagnose a faulty ethernet cable in the past?
Message posted on 25 Mar 2021 03:07 PM
Answer - No true. Yes it does work as a sound system if they are all connected to the same "access point". If you have anykind of mesh then only those devices connected to that access point will work as a network and the "controller app" will only see those devices that are on connected to the same access point.
The wifi has a SSID and each access point has a subsidiary BSSID and Sonos cannot cope with devices being with different BSSID. Sonos support say this is because the access point are not transmitting the right SSPD protocol.
I have spent hours with Sonos support - no solutions. I would not buy Sonos kit again!
Message posted on 25 Mar 2021 03:19 PM
This not to say Sky are faultless - from posts elsewhere their implementation of a mesh is fatally flawed. It sends endless SSDP network traffic that pulls the performance of the whole wifi down. This is addressed in other posts - apparently there is a fix coming down the line - 2 releases time.
I would just like Sonos and Sky to talk together (digitally and physically) and resolve this mesh issue for customers - there should be no turf wars.
My solution for now - I have turned the whole SkyQ/Sky mini mesh wifi off and rely on the main wifi for all devices and everything works. I have SkyQ and Sky mini connected to Ethernet. The advice on how to stop the wifi being swamped by SSDP traffice generated by Sky is to leave the Sky mini left on (no standby). I have therefore lost the benefit of extending the wifi into the garden using the sky mesh - I am not impressed by either of these companie
Message posted on 25 Mar 2021 03:23 PM
I use a BT Wholehome Mesh network and have been using Sonos since 2013. Never experienced a droput in all those years.
Message posted on 25 Mar 2021 03:35 PM
"I use a BT Wholehome Mesh network and have been using Sonos since 2013. Never experienced a droput in all those years."
Clarification Questions - Sonos 2? do BT mesh access points have different BSSID? do you have SkyQ and Sky mini?
Then this does point to Sky "mesh" having the issue with Sonos "broadcast" messages. However as a mere consumer I would like to knock their heads together though as it will take them both to work out the solution.
Message posted on 25 Mar 2021 03:41 PM
BT Mesh and possibly all mesh have the same SSID. That's how they work i.e. you get seamless access to the best WiFi signal as you move around. The system will move you from one disk to the next strongest unit. I have SkyQ Main and Mini which also work brilliantly on 100% WiFi. I couldn't run SkyQ period just using a router alone.
Message posted on 25 Mar 2021 04:00 PM
That's not the case. I have one Sonos connected to the router by ethernet, which takes all my Sonos off my WiFi and onto Sonosnet. This means the speakers cause no drain on my wifi bandwidth at all, which they otherwise would do (and indeed used to do - most Sonos use 802.11b/g, and any wifi setup is only as fast as its lowest protocol).
Message posted on 25 Mar 2021 04:11 PM
"BT Mesh and possibly all mesh have the same SSID"
Of course thats true - its how it works! Howver there is BSSID as well, which works as a subsiduary identifier for each access point.
The problem I have (and other posters have) is that if your Sonos controller app is connected to a access point with a different BSSID to your Sonos devices (although they all are connected to the same SSID of course) then the app will not see that Sonos devices (whether connected on Wifi only or Sonosnet).
Is there anyone out there with Sky mesh that could help? Obviously you have a different set-up.
Message posted on 25 Mar 2021 05:20 PM
@Rhonny Sonos had zero effect on my mesh network. It never breaks sweat even when running nearly 30 devices.
Message posted on 25 Mar 2021 05:38 PM
@Piesarus “Sonos had zero effect on my mesh network. It never breaks sweat even when running nearly 30 devices.
That is good for you - meanwhile anything to add to solve the issue?
Message posted on 25 Mar 2021 06:52 PM
Okay, cool. I'll try it. Thanks for your help.
Message posted on 25 Mar 2021 10:12 PM
@woodchal yes, ditch Sonos net you don't need it.
