5
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky glass puck
This message was authored by: jjeanstv
Sky glass puck
I get sky glass installed on Friday. I have purchased 2 pucks for my tv in kitchen and bedroom. Unfortunately the tv in kitchen is not 4K uhd and a new tv with smallest screen is 32in which might be too big for my kitchen area. Can I link the puck to a 4K uhd monitor instead of a tv?
This message was authored by: GD1 Answer
Re: Sky glass puck
Yes if the monitor has HDMI in, however monitors don't tend to have onboard sound so you'd need to find a way to do that.
As long as your current TV in the kitchen works & has HDMI I wouldn't be too fussed about not having UHD on that particular set.  HD will be fine.
Locked
Re: Sky glass puck
Avatar for jjeanstv
Level 2 icon
Re: Sky glass puck
Thank you for reply...will wait until Fri and see what happens. Looking forward to this!
This message was authored by: nocolagibbons
Re: Sky glass puck
How much are the pucks please?
Re: Sky glass puck
£50, I believe.
Re: Sky glass puck
Thank you yes I found it 👍
Locked
