Discussion topic: Sky connection to AV Receiver
Message posted on 02 Feb 2020 12:45 AM
Re: Sky connection to AV Receiver
The trade off in running optical from box to amp is if you have any apps on the tv (if smart) or any consoles or dvd/BR players attached would not get any sound to amp
running from the tv allows you to use more kit
Message posted on 02 Feb 2020 06:16 AM
@mikenmia unfortunatly many TVs either cant pass DD from an HDMI input to the ARC connection or introduce a delay when doing so which shows up as a lip sync issue which is why the Optical route is often the best solution. No right or wrong in this game just what works best for you.
Message posted on 02 Feb 2020 08:42 AM - last edited: 02 Feb 2020 08:43 AM
Message posted on 02 Feb 2020 05:48 PM
Message posted on 02 Feb 2020 06:21 PM
It should be fine. The signal uses light, and light won't degrade over three metres.
Message posted on 02 Feb 2020 09:27 PM
@Rhonny Many thanks, I have just ordered.
Message posted on 08 Feb 2020 10:12 PM
Message posted on 02 Apr 2020 02:24 PM
Not sure if this is the right forum for this problem so please redirect me if needed.
I have Sky Q via HDMI to my Bravia with ARC for sound to my Marantz SR6009. Last month I lost sound through the amp. Sound is still there through TV speakers and I am now using optical from TV to amp without issue. However this means that I cant watch Amazon Prime through the TV and have sound from the amp unless I change the optical connections each time (real pain). Marantz tech support have confirmed that it is not my HDMI board that has gone as it works fine with BlueRay etc. They did advise that there is a know problem with HDMI not working following firmware upgrades on the SkyQ box. Anyone else experienced this?
Message posted on 02 Apr 2020 02:46 PM
@matt+castle If you're not getting sound via ARC from the TV with the Prime app, it sounds like a TV or receiver issue, not anything to do with Sky Q.
Forgive me for stating the obvious but, have you thought to power everything down at the socket in order to establish handshakes all round? Or experimented with different HDMI cables?
Message posted on 02 Apr 2020 03:06 PM
Hi Drexl+Spivey
Tried everything, reconnecting all cables, different HDMI cables, powering down etc. I have been getting sound from Sky Q using HDMI through the AVR cab/sat setting for about a year. Then it just stopped working. Now I can only get Sky Q sound using the optical cable on the AVR tv/audio setting. I also get Sky Q sound if I use the tv speakers. Not too worried about Prime through the TV app, dont use it very often.
Message posted on 02 Apr 2020 06:06 PM
@matt+castle I have two issues with Marantz, one that carries over to Denon receivers...
Firstly, Marantz sound superb but, are let down by their styling (in my opinion). I had an SR6014 last year for a couple of weeks and just couldn't get on with the tiny display. which is a shame because it was the best sounding receiver I demo'd.
Secondly, both Denon and Marantz (Sound United) insist on a weird layout of their HDMI inputs, knowing it is to the detriment of some components you connet to the unit.
Marantz have located the CBL/SAT input furthest from the output, knowing it will affect 'clocking'. Denon themselves explain it far more elequently than I, please refer to here - https://denon-uk.custhelp.com/app/answers/detail/a_id/5531/session/L3RpbWUvMTU0NjQ3NjExMi9zaWQvTWhlb...
So, with that in mind, can you please try using the HDMI input nearest to the HDMI output for Sky Q?
I can tell you the I've arranged the layout on the rear of my Onkyo to read like this; Sky Q, 4K UHD player, PS4 Pro and FireStick.
That's not how it's labled on the rear but, I consider Sky Q to be the weakest link in the video chain and needs all the help it can get. You can just change the input names via your receiver remote and onboard menus.
Obviously, if you're pulling out and rearranging HDMIs, this should be done when the unit is powered down at the wall. In fact, I would power everything down as this will again establish all the handshakes.
If you do try this, can you please let me know if it's succesful?
Message posted on 09 Apr 2020 10:14 AM
Problem solved. Unplugged everything and disconnected from mains power, re connected and it all works fine now. Thanks for your advice
Message posted on 29 May 2020 02:36 PM
Hi, can someone please help me, I have just had Sky Q fitted on Monday, and the fitters just connected an HDMI from the sky box to the TV , and my optical cable from the sky box to the AV unit , initially it worked fine with my AV which is an photo H T -R494, and worked great with my old Sky hd box, but now I can't get any sound, can anyone help, Paul Ions.
Message posted on 29 May 2020 03:45 PM
Hi,my AV unit is an Onkyo HT-R494 not a photo, thanks, Paul Ions.
Message posted on 29 May 2020 03:58 PM
My understanding is as below re optical. My Yamamha picks up dolby digital plus signals using the HDMI ARC route.
The types of digital audio signals that can be transferred by a digital optical connection include two-channel stereo PCM, Dolby Digital/Dolby Digital EX, DTS Digital Surround, and DTS ES.
Digital audio signals, such as 5.1/7.1 multi-channel PCM, Dolby Digital Plus, Dolby TrueHD, Dolby Atmos, DTS-HD Master Audio, DTS:X, and Auro 3D Audio cannot be transferred via Digital Optical connections. These types of audio signal formats require the use of HDMI connections.
