18
Discussion topic: Sky Talk no calls
This message was authored by cryan This message was authored by: cryan
Sky Talk no calls
Hi hoping someone can help. We have sky broadband and talk. For the past month we've had no incoming or out going phone calls (I know it sounds daft but there's only really a couple of people that call on it - elderly relatives and most of the time we use mobiles)
anyway we have internet but the voice light is not lit up on the box, I've checked all the cables. It's not showing as being a fault on the line and I've reset the box a couple of times but it's still not working.
can anyone suggest anything?
This message was authored by Tom-W19 This message was authored by: Tom-W19 Answer
Re: Sky Talk no calls
Posted by a Sky employee
After speaking with cryan we ran a line test which detected an external fault and arranged for an Openreach engineer to resolve this shortly.
It was a pleasure speaking with you today cryan.
Tom
Locked
This message was authored by Daniel0210 This message was authored by: Daniel0210
@cryan Have you tried this link? https://www.sky.com/help/diagnostics/fix-problems-with-your-phone/check-your-phone-line
If that doesn’t help you will have to contact Sky. They can check your line and if an external fault is found they will pass it to Openreach to investigate/fix.
cryan
Hi Daniel,
thabksmfor reply. Yes tried that and no joy with it!!
@cryan Try contacting Sky by other means. If you have Sky Mobile you can dial free on 150. If you can't, then post back on here and someone with the relevant level may escalate your post to Sky.
This message was authored by Lisa-P1987 This message was authored by: Lisa-P1987
Hi there, I have escalated this post to our community chat team. Look out for a chat bubble here on the community forum or an email invite. We look forward to talk to you 🙂
Lisa - Sky Tech Team Expert
This message was authored by Mark39 This message was authored by: Mark39
@cryan as @Daniel0210 posted, you'll need to report this to Sky. I've highlighted your post to them, so hopefully one of Sky's Community advisers will be able to help you via the forum. Look out for a blue chat 'bubble' or an emailed invitation to a live chat over the next few hours. You could, of course, give Sky a call, of you prefer.
Tom
cryan
probably shouldn't say this but a little bit infurated. Was told that there was an external fault with the phone and an engineer would be out they wouldn't have to attend the premises.- I thought this would be great as im
working from and had quite enough of Sky stopping me from doing my job, for this week!
only to get a call this afternoon to say they want to come round and test the line again!! So yet again I'm going to be stopped from doing my job!! I'm going to start billing sky soon for all the lost hours!!
@cryan You may be able to get some compensation from Sky depending how long you were without your services.
https://www.sky.com/help/articles/auto-compensation
This message was authored by Mannykamie This message was authored by: Mannykamie
Hi can ne1 help plz
@Mannykamie Maybe, but we'll need more information.
Like what sorry
@Mannykamie
I presume as you've posted on this thread you have a problem with your landline. What is happening? What have you tried?
If your landline phone line isn’t plugged into the back of your broadband hub, use this link to run a test on the line.
If that doesn’t help, post back on here and some of us here will be able to escalate your problem to Sky. Openreach normally aim to fix reported faults within 3-5 working days.
This message was authored by Lynda+P This message was authored by: Lynda+P
Hi, I am disabled and use lifeline. Unable to make calls. I need to ask for it to be expedited. I am elderly and live alone. Open reach booked but I don't know when. Any advice ? Thank you
@Lynda+PWhen was this fault reported to Sky, this will help to give you further information of when this fault might be fixed. Also if you are able to check my account, track orders. If you are unable to ask someone you trust to check this for you.
Locked
