76
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Talk incoming calls get Line Engaged Tone
Thread created with new thread title to reflect current landline issues.
This message was authored by: KevNewMedia Answer
Re: Sky Talk incoming calls get Line Engaged Tone
Posted by a Sky employee
Thank you for making us aware of this fault - we can confirm the fault is now resolved.
Thanks for your patience.
Kev
Community Manager
Locked
This message was authored by: Peter+Onn
Switched to sky this morning, broadband OK, Outgoing calls OK, incoming gets a permeant engaged tone
Re: Switched to sky this morning, broadband OK, Outgoing calls OK, incoming gets a permeant engaged
Now getting server unreachable error when dialing from mobile rather than an engaged tone
If you have Sky VOIP, previous posts suggest that it can be up to 24 hours before the phone service is fully activated. It may be worth you waiting until tomorrow, then restarting your Hub by switching off at the plug for 30 seconds or so, to see if it resolves.
This message was authored by: ALBIE125
My landline phone will not accept incoming calls but will dial out
When someone calls my land line the phone gived the engaged tone, but I can dial out
Re: My landline phone will not accept incoming calls but will dial out
@ALBIE125Have you recently joined or upgrade your Sky package or did this come out of the blue?
This message was authored by: ATPIPIN
landline incoming
I can dial out on landline but can't receive any calls.
When I ring from my moblie to my home landline I just get engaged tone.
please help
This message was authored by: NikRob81
Re: landline incoming
Exact same is happening here and I've just been told to check back in 48 hours to see if there is an update on the service. Not good enough. Paying for a service thay doesn't even work!
@Mark39 I've been getting told this for the last 48 hours with my landline... still not working. Shocking service to be honest
This message was authored by: Kate1626
im currently having the same issue fibre broadband installed today was receiving incoming calls fine and now nothing, home phone will let me dial out not accept any incoming calls.
gobe through all the step by steps and everything looks fine
ive been on hold to sky for 20 mins now 😞
This message was authored by: Andy168
We've got the same problem and it just came out or the blue
We've got the same problem. When we phone landline we get engaged tone, even though they're not in use
@Andy168  & @ALBIE125  The quickest way to get this resolved is to call Sky on your landline or mobile would be better just in case Sky wish to test the line and not able to call you back.
When you call you will be asked if this is about Sky mobile say " No ", you will then be asked the nature of the call say " Technical ". You will then be asked for a mobile number give it if you are not already calling from your mobile, you will then be asked to hang up when you get the text " DO NOT HANG UP". You will then be asked do you wish to hang up say " No ", you will then be put into the queue to speak to an advisor.
This message was authored by: Graham+Norfolk
Sky Talk -
I can make outgoing calls, but when ringing in, the phone line appears to be engaged, I'm not sure how long this has been the situation. turning the router off and on doesnt work.
This message was authored by: Jayleigh95
Incoming calls not working
Had my broadband and phone for just over a week, all has been going good until today? For some reason no calls are coming through to the house phone, tried ringing off my own phone and there isn't even a dialing tone just completely quiet, although I can make calls off the house phone, just not able to receive them! It's not even ringing at all, been on hold to sky for over an hour! Someone please help me, I've undone everything and turned it off and on, nothing is working!
Locked
