This discussion topic is read only Discussion topic: Sky Q box rip would appear.
This message was authored by: TwoBit
Not had any really issues with sky q until tonight.
Currently have virgin media run through a deco m5 system as WiFi needed boosting. As with all networks, occasionally you need to reset them, done this tonight and that's been the sky box in meltdown.
Previously the box, router and deco has been unplugged numerous times and always started up and worked fine....until last night.
Now the box will constantly freeze on recordings and live TV, tried a soft reset and sadly now going to try a hard reset.
What makes me think its got more deep lying issues, is the fact when it goes off the green light is on and the fan is on max speed 🤦‍♂️🤦‍♂️
Locked
This message was authored by: TechmanagerMal
Re: Sky Q box rip would appear.
  • It would appear to be an HDD fault, I would contact Sky soonest.
Passing on the tips I have learned in over 25 years as a more than satisfied Sky customer.
Avatar for TwoBit
Level 3 icon
Thought that, got an engineer coming Sunday.
Locked
