Discussion topic: Sky Q and Sky+ In the same household - Some questions
Message posted on 12 Feb 2021 07:32 PM
Re: Sky Q and Sky+ In the same household - Some questions
@Jackdoesthings You could purchase a cheap PS3 or PS4 and use that to play Sky Go directly on your TV. Would be nicer to use than a laptop. Can even get a dedicated remote control for it. Try to get one without too much fan noise if you can though.
An xbox 360 can do the same thing I believe if you have one lying around.
Message posted on 12 Feb 2021 07:47 PM
Why not Xbox One or Xbox Series S|X?
Message posted on 12 Feb 2021 07:51 PM
@Annie+UK why not indeed. It would just cost a lot more if trying to buy one just to watch Sky Go. You could pay €500 for a PS5 as well but might not be worth it just for Sky Go 🤷♂️
Message posted on 12 Feb 2021 07:56 PM
That's why I included Xbox One that will be dirt cheap secondhand especially the day one editions
Message posted on 08 Nov 2021 07:23 PM
My wife can't see the screen as it's to bright
Message posted on 08 Nov 2021 07:42 PM
@Amber8878 that's a bit random. Can you explain further?
Message posted on 08 Nov 2021 07:44 PM
@Amber8878 wrote:My wife can't see the screen as it's to bright
Turn the brightness down on your TV's internal menu may be a good way to reduce the brightness.
