The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
30 Jun 2021 10:38 AM
Posted by a Superuser, not a Sky employee. Find out moreI have an LG 43UK6300PLB TV one of Sky's free Black Friday Deals
Sky+HD had this handy feature in the form of a pop up on your screen that required you to be constantly clued to your screen so you didn't miss it.
Auto view was another handy feature on Sky +HD where it automatically changed to the programme you set the reminder for.
Yes I did have Sky+HD boxes yes I used reminders and auto view do I miss them no not really Sky Q for me was a cheaper option same amount of boxes for less so reminders and auto view didn't enter the equation.
Reminders on Sky Q are achievable at the end of the day it's just a visual prompt to tell you that your programme is about to start.
Let's get started and rack up those reminders F1 this weekend don't want to record no problem.
1. Make sure your LG Magic Remote operates your Sky Q box.
2. Make sure your voice control on the LG Magic Remote work.
3. If doesn't matter if you have your Sky Q box in standby mode.
4. Sky Sports F1 HD channel 406 Press the voice control button on LG Magic Remote and say " search programme 406"
You will get this screen next press up and select Upcoming TV
Select Live Formula 1 Motor Racing and you'll get the screen below.
Set reminder for 406 Sky Sports F1 Practice 1 10:00am Practice 2 13:45 pm
Click the down arrow in the Friday box to set reminders for Saturday and Sunday.
No reminders are set for Sunday as work is calling so record once has been set🤣🏁
I'm sure the pop up reminder stays longer on the screen compared to Sky+ and I'm also sure that it will change to the programme if you are not already watching 406.
I'll test this out later just to be 100% it works as it should.
Apologies for the winded post hopefully some may find it useful some may not but hey ho you can't win em all🤣🏁
30 Jun 2021 10:43 AM
Just to be pedantic, that's not 'Reminders on Sky Q', but 'Reminders on LG' ; )
Neat hack though.
30 Jun 2021 05:55 PM
Posted by a Superuser, not a Sky employee. Find out moreUpdate set a reminder today just try out if it worked correctly.
Did get the pop up as well.
It didn't automatically change channel apologies for that
With the LG Magic remote press the voice control button and say " programme 406"
If you haven't got the LG magic remote use your Sky Q remote when you see the pop up my work here is done.
30 Jun 2021 06:00 PM - last edited: 30 Jun 2021 06:01 PM
I don't think it could: there's no shared means of communication by which the television could generate such a command to the Sky EPG interface.
