Discussion topic: Sky Q Mini Boxes all showing Technical Fault
Message posted on 23 Dec 2021 10:27 AM
Hoping someone can help me as I've tried all solutions on the forum I think. Yesterday all of my 4 Mini Boxes showed Technical Fault in the screen preview and the TV guide fails to load etc. I've rebooted all boxes including the main box. Rebooted my internet. Reconnected all boxes to each other. They connect just won't show anything. I have reactivated the mini box option on the main box, ran software updates on all boxes but they still show the same error. At the end of my tether now as got a house full for Christmas. The main box works as normal for all viewings and recordings and no other devices in the house are suffering internet issues. Don't know what to try next.
Message posted on 23 Dec 2021 10:30 AM
Re: Sky Q Mini Boxes all showing Technical Fault
Hi @Paul+Hull
Try a Reset Settings in the hidden menu on the main Q box.
Press 1 & 3 together on the remote and follow onscreen instructions to re pair.
Message posted on 23 Dec 2021 10:48 AM
Thank you @oldfella . Just tried that and also reset settings on mini boxes but still getting the same message. Setting show that the boxes are connected to the internet and connected to the main box.
Message posted on 08 Mar 2022 05:59 PM
Hello did you sort this issue as I'm getting the same problem
Message posted on 08 Mar 2022 06:24 PM
@Helensilver Did you read the reply above as this details how to resolve the issue.
Message posted on 04 May 2022 02:41 PM
I have the same problem, 'Technical fault' showing on my tv connected to the mini box, connections to network and Sky Q box showing ok. Tried the reset on the main box to no avail. After some days of no service yesterday the programmes came back on and were fine. This morning, back to 'Technical Fault'. Engineer's visit required I think (again!)
Message posted on 04 May 2022 04:47 PM
Hi there Angliaman, I will escalate this to our community chat for you. Please look out for an email or chat bubble. We look forward to speaking to you 🙂
Lisa - Sky Tech Team Expert
Message posted on 04 May 2022 04:54 PM
The remote engineer fixed this issue for me. My router tra smits in 2.4 and 5ghz. The main box was receiving on one frequency but the mini boxes were linking to the main box on the other. In the engineer menu there is an option to switch off either frequency so all boxes transmit and receive on the same one. I've not had an issue since this was resolved for me. If you can't see the options it's def worth booking a remote engineer call.
Message posted on 04 May 2022 09:21 PM
Thanks Paul, I'm awaiting a call from Sky. Whilst the problem will probably be solved by your suggestion (as in the past) my annoyance was with the current trend of companies making it very difficult to find any contact details on their websites. Coupled with the usual 'we're very busy at the moment but don't worry you're 125th in the queue' telephone responses it's just another nail in the coffin of real customer service!
Message posted on 04 May 2022 09:23 PM
Thanks Lisa, I will be out until 4.30 tomorrow but home all day thereafter.
Message posted on 04 May 2022 11:44 PM
@Angliaman The whole country is short staffed, hospitality, retail and media. Patience is a virtue. Impatience is a pain in the **bleep**. When you do get through the fellow humans on the other end of the phone will do their very best for you.
Message posted on 08 May 2022 01:11 PM
Update – Thanks for chatting to us Angliaman. Unfortunately, there was no further response on the chat in 48 hours, we are still waiting to help you. If you need our support let us know and we can re-escalate to our chat team. Your chat has been closed now. Thanks 🙂
