Discussion topic: Sky HDR
Message posted on 31 May 2020 11:42 AM
Re: Sky HDR
@pdixon0 wrote:
And of course my posted screen shot won't show either, brilliant.
@pdixon0 only community managers and Oracles can approve pictures, I've just approved yours so should show in a few minutes
Re: Sky HDR
@Rhonny Ah OK, makes sense!
Paul
Sky Q 1TB UHD (HDR) | LG OLED55C9PLA | Yamaha RX-A880 Aventage | PS4 Pro
Sky Q Minibox | Samsung LE37B650T2W
Sky Fibre Unlimited SR203
Message posted on 31 May 2020 11:47 AM
Re: Sky HDR
@da1e7150- dunno if these help? I've got the 1TB box from a new install earlier this year and HDMI2.1 compatible HDMI cables. Setup is Sky Q thru Yamaha RX-A880 to LG 55C9.
Paul
Message posted on 31 May 2020 11:56 AM
Re: Sky HDR
@TheDeathOfRats Another anomollay is that if the box breaks down after the first year, Sky expect the customer to pay to get it repaired - why is that - if the box belongs to Sky and it has failed through normal use, why should the customer be responsible for repairing Sky's assets.
No no unlike +HD the maintenance cost is in the subscription and Sky will repair/replace free if needed.
The grey area is the dish and cabling which Sky say belongs to us and is guaranteed for 12 months however Sky do not seem to charge to fix faults on either.
Thanks for that info, that's good to know. That isn't what I was told by the salesman and at the time made me decide not to buy another mini.
Before you say I was 'biting my nose off' it was a casual purchase that I wasn't really sure I needed, but I would have 'bought' had he replied as you did. It is often the case that sales and support staff are sometimes ill-informed, things that I have heard of said over the last few days include
"all 2TB boxes can reveive HDR" (not true)
"the V1 boxes will be able to receive HDR after a software patch" (this might be true but I don't think so)
"what is HDR, there is no feature called HDR" (not true)
"faulty boxes are always replaced on a like for like basis with the same version" (not true)
Cheers,
Nigel
Message posted on 31 May 2020 12:02 PM
Re: Sky HDR
I got HLG from my v1 box just needed a third part device to tell tv it was HLG. So you can solve but you have to buy something. Alternatively get box swapped and lose recordings!
kevin
Message posted on 31 May 2020 12:05 PM
Re: Sky HDR
@Laing1 Thank you 👍
Paul
Re: Sky HDR
Faciniting!! I have just checked on the internet, the HDfury seems to be able to do this, but not much information given as to how.
There is some software that comes with the box (?) where you can 'add' the signal that the original V1 cannot control to tell the TV (LG C7 OLED that is HLG compatable) that this signal IS HDR? Am i correct?
I guess you know this works because you see the TV show HDR signal?
Any help appreciated. the £130 ish price compared to what Sky may cahrgae and the rest of th setup seems acceptable.
Message posted on 31 May 2020 12:05 PM - last edited: 31 May 2020 12:10 PM
Re: Sky HDR
@Lp12man If you mean "Fury" it is just telling you what you want to see it will not make an original 1TB box give HDR.
Message posted on 31 May 2020 12:09 PM
Re: Sky HDR
What is the extra kit you purcahsed? HDFury??
Are you sure this works? i have a 2TB V1 box and would love to make this work. 🙂
Message posted on 31 May 2020 12:22 PM
Re: Sky HDR
@TheDeathOfRats I've had support staff who've never heard of HDR too. It's pathetic...
Re: Sky HDR
Message posted on 31 May 2020 12:25 PM
Re: Sky HDR
Used old hdfury linker
gave me these.
now you need to copy some code into the configuration program. Which I was given but there is a server where you can generate with so many bits etc.
hdfury not cheap though although available on ebay. My unit from 2017.
kevin
Message posted on 31 May 2020 12:27 PM
Re: Sky HDR
MEAN NITS not BITS!
Message posted on 31 May 2020 12:29 PM
Re: Sky HDR
@Silversurfer8 I have a linker and goblue dongle I had it from when I had my c7 for the dark game mode issues pm if you don't want to spend 130ish I don't need mine
Message posted on 31 May 2020 12:32 PM
Re: Sky HDR
Btw hdfury been going for ages, gave me a device which added hdmi to my old Sony crt projector. Check out reviews at AVSFORUM or AVFORUMS
kevin
